  • Replies 515
Posted Images
LOL at the Cats vs Freo game
5 minutes to go in the 1st and Cats are scoreless (no majors at least)....what the...?!!
Freo have won pretty much all there 1st quarters this year...they then go on to loose the last 3.....CMON THE DOCKERS....lol
Ryan :D
https://www.sau.com.au/forums/topic/266313-footy/page/12/#findComment-4671704
good night to be a bombers member :whistling:
one of the few that picked them i reckon i will be. Hopefully the commentators were right in saying we could be fighting for a top 4 finish ths year! Who would have thought it with such a young team.
Hopefully this is the start to a good weekend!
https://www.sau.com.au/forums/topic/266313-footy/page/12/#findComment-4681703
massive last quarter made it a somewhat respectable loss.........if there's any such thing, lol
im hoping the power dont boot choc
hes a pretty decent bloke by all accounts, and considering he took them to a premiership and graeme cornes never managed it, they'd be doing him a bit of a disservice to not renew his contract
-D
https://www.sau.com.au/forums/topic/266313-footy/page/12/#findComment-4684087
Is Cornes going to get the job at the power?
not that i know of, i wasnt inferring that he was, i was more drawing comparison between williams and cornes because i forgot that jack cahill was their first coach. silly me
but yer. as much as the power have sucked and that im not a fan, choco did take em to a premiership which means he does at least have the bones for it, i'd more blame the players at this rate... the power absolutely MUST get rid of the chokers tag if theyre gonna be taken seriously, and that includes chasing points for the margin when you at least know the other team is going to win.... its like they give up most of the time, which is in nobodys interest, most of all the paid spectator
its no wonder that port supporters are generally feral inbred monkeys who spit and curse and then go out and steal car radios. if my team lost so badly, so often, i might become them :~( truly afraid here
-D
https://www.sau.com.au/forums/topic/266313-footy/page/12/#findComment-4684187
Choco will only go on his own terms, the club would never tarnish the image of such a club legend by sacking him. Hes been there for the Power through thick and thin, i wouldn't be surprised if he calls it quits after the H&A season.
https://www.sau.com.au/forums/topic/266313-footy/page/12/#findComment-4684218
Again. another media torn complication.
Choco has the 2nd highest win loss ratio in the league. He has won a flag. Been in a GF. (lost by alot) but still got there. Won NAB cups. Influenced a lot of young players who stand by him. But he must go. why /.?
negative feedback by I hate to say it some of the Port fans who turn on the coach. Media pick up on it too.
Why doesnt M malthouse get the flick too ? what about some of the other lame coaches ?
To be honest Im not too fussed anymore if he goes. It seems he will if you have listened to alot of radio today. However my question is simple. Who is a better coach to take over ?
https://www.sau.com.au/forums/topic/266313-footy/page/12/#findComment-4684263
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
