Terios hits 131.8 at SAS
Guest [ryan]
SPL is mad, sittin in daniels swift with like 140db of bass in ya ears is an awesome experience
low bass rocks too, u feel it more than u hear it :)
if it was 140db of treble im sure i would feel lots of pain in my ears, but for some reason bass doesnt affect them :)
not bad miles, make a larger ported box for it maybe with slot ports or something perhaps you could make 135+
Why would you want a road driven car that goes faster than 110??
Do you go to the Northern Territory often?
See any simarlarities?[/quote:81acd89f9a]
valid point but a stupid comparison. sorry don't mean to be rude but it is a silly comparison.
you are comparing the speed of a car to the db of a sound system.
CAR- you strive for a good top speed and in the process you get a relatively fast bottom end. you enjoy your bottom end due to the higher top end and you make use of both whenever and where ever possible.
SYSTEM- you strive for more db and you don't get more quality at lower db relative to your peak db. you can't use your peak as you will go deaf in the process so you are left with a system that has no complete use other than to show off or win awards. same thing if you ask me.
i don't know, i might sound silly myself but this is my 2c's
Guest [ryan]
George, All depends on who you are and what you like. Some people like Sound Quality, Some people like SPL, and don't care about the quality. Just like some people prefer rice over performance, for example. All comes down to user preference basically. SPL is harder to acheive than you think, it's not as simple as chucking in a big amp and big sub into a car. Alot of work and factors come into play when you're trying to acheive big SPL. You have to play with different boxes, different box positions, different porting techniques. There are other factors, but i'm no SPL expert and won't bother getting into all of that. It's just the same as getting more power out of a car - sometimes it's not as simple as it seems. You can't just bolt on a T88 and blast 2bar+ into the engine, more factors come into play. See my point?
to each their own ryan. i have no problem with anyone spending their hard earned cash on a system or a gaybrush as you put it for example.
i like my music dude, more than you might think after reading my comments on this thread but i still can't warrant a 140db system. that's just like paying for the blood to flow out of your ears.
besides, you know me, performance always comes before image.
Guest [ryan]
Eh, not all systems are 140db :)
120db is louder than you think, 140db is f**ken loud. But yeah like you said, Each to their own. I would prefer to spend a bit of money on performance, bit on looks, and a bit on a nice Sound Quality system, I prefer to enjoy listening to the music rather than be able to gloat about its db rating, but thats me. :)
It's all good :)
Guest Daihatsu_Dude
See any simarlarities?[/quote:80a18c166f]
Very Much Agree Dion, Photos of the Terios @ Sas are up now, goto www.froggy.com.au/nissan and follow the Sydney Auto Salon Link!!
Guest Daihatsu_Dude
"]SPL is mad, sittin in daniels swift with like 140db of bass in ya ears is an awesome experience
not bad miles, make a larger ported box for it maybe with slot ports or something perhaps you could make 135+[/quote:6b86bff7a6]
Thanks for the feedback Ryan, I would not say that I have the best system, but my result impressed a few people that day and my self. Since then I have had a new box made up with thanks to Oscar and im planning to get a 4CHN Jaycar AMP for more power, so when I goto my next SPL day or event, I can hopefully hit them high 130.0's
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
