I'm just wondering what tints are legal, like im after silver reflection tint but im pretty sure thats illegal and i want to keep mine street legal, other wise if all colour tints are illegal whats the darkest you can go and how much is it to tint a car normaly? around 200 or is it around 500 or even more?
thanks for your time :D
https://www.sau.com.au/forums/topic/267290-legal-tints/
