Well I have had these seats sitting in my bedroom for the past 2 years now without doing anything with the as they were to difficult to adapt to fit into my Laser ...
Now that I have bought an R32 skyline and the seats are just sitting there collecting dust I thought enuf is enuf I will finally put them into a car
So the new Saas SP3003 seats in red and black are going to be put into my R32
Just ordered a pair of R32 seat rails from justjap in sydney without a doubt I will probbably have to modify the rails slightly to make them fit but atleast the rails are suited to the R32 :laugh: so installing will be much easier hopefully...
Neways here is a pic of the seats
Hopefully the rails arive in the next couple of days :thumbsup:
https://www.sau.com.au/forums/topic/267341-new-seats-for-the-gts/
Be careful when adapting aftermarket seats to standard rails.
If you dont have a certified automotive installer (someone who has been trained in fitting baby seat bolts, seat belts etc) make up the brackets for you, not only are you risking your own safety but your car can be defected... You must be able to produce an engineers certificate for the install for it to be legal.
2nd that!
I am getting prefabricated seal rails to suit aftermarket seats that bolt straight into the R32 from Just Jap in Sydney .... $400 for the pair of rails delivered
No way in hell am I attempting to adapt them to the stock rails again ... stuff that I have done that in another car already and that was a bit of a stuff around job eventually got the seats in my other car and they work great but was a big over engineered adaptation to the stock rails ... too much stuffing about
I like the term 'over engineered', LOL! Safety is paramount. Like Bullet32 has said, you can get defected for no engineers cert', but that's almost anything these days. Difference is, seats tend to stand out, and it's an easy starting point for the rozzers to lube up their rubber gloves...
All good ... nothing that they can defect me for in my car ... besides maybe the window tint ... but that's only really an issue at night time if they really want to be picky...
I keep the rest of the Car in tip top condition mechanically
Also the Seats are ADR approved :) so there shouldn't be any issues with them
Also the Seats are ADR approved :/ so there shouldn't be any issues with them
I'm not trying to pick on you Mick but it doesnt matter if the seats are ADR approved or not... All that means is that the seat itself is considered safe to use on Australian roads.
Even if you get pre-fabricated aftermarket rails that bolt directly on to the car and seats, you still have to be able to produce an engineers certificate for aftermarket seats.
The reason for this is that if you have a crash, whether its a big front, side or rear ender or even a small shunt/nudge, if your seats are not 100% correctly installed you can easily suffer severe, permanent back and neck injuries that will haunt you for the rest of your life.
I have a close friend who is a certified seat belt, restraining bolt and seat fitter who has told me the horror stories of people who have cut corners in these situations and believe me when I say - I got chills down my spine listening to them.
Do it once, do it right - For your own safety. :(
Yeh, only seats you can change to without a certificate is ones from the same model. So, GTR seats are okay!
Depending on what type of seat(ADR approved or not) you get and the level of modification requires a different certificate. I think it'll be easy to get it certified if it is all ADR approved. That's my understanding anyway:
http://www.infrastructure.gov.au/roads/veh...on_3Feb2006.pdf
Edited by StinkyPoo
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
