1987 model
VL TURBO
Maranello red with a pink pearl
Auto
Exterior
resprayed red with a pink pearl over asteroid gray
paints in decent condition
calais rear lights
silver interceptors
INTERIOR
-grey cloth calais interior
-calais door trims + glove box
-momo racing steering wheel
-5" monster tacho black face, blue illumination (retail price $699) has built in shift light, water temp, oil pressure, and volt power
-i have 2 tan leather fronts seats + 2 black leather carbon fiber style front seats i can also chuck in
Engine
-As new condition (recently freshened up)
-t3 high flowed turbo in gud nick
-FMIC keept above the bar for police sake
-rebuilt head + cometic gasket kit + lifters + springs + stage 2 crow cam
-Just done major service including
Spark plugs
Oil + Oil filter
Fuel Filter
Air Filter
AUDIO
-DVD/IPOD/TV/GPS headunit
-6x9 500w pioneer speakers
-2x 15" kicker comp subs, only 1 will be sold with car
Mechanical tests and inspections welcomed and encouraged.
Car must be sold asap, i have lost my license and am too tempted to drive it
so i need the cash to fund an even faster project
For RWC
-new tires-
Prices as follows
-$5700 as is
-$6000 with 4 new tires
Call anytime to discuss
0433049322
Lev
location - Keysborough
will accept trades depending on what with cash adjustment depending
https://www.sau.com.au/forums/topic/268626-fs-vlt-rb30et/
  • 1 month later...
the bloke just told me he got the head ported for "95 bucks" so if you are thinking of buying this car, that should reflect on the quality of the build. gl with it mate.
Edited by sebastion
https://www.sau.com.au/forums/topic/268626-fs-vlt-rb30et/#findComment-4700169
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
