Due to the recent purchase of a new toy - the GTR is now up for sale.
Some of you may already know the car from earlier track days (Bris)
This car has been my everyday driver for nearly 5 years. It has also been extremely capable on the track throughout that time.
I have listed below a list (that I can remember) of mods - there are also many others such as stereo and blue tooth connection etc which are not listed.
I have included a couple of pics. I am happy to send more if required.
Current asking price is $50,000-00 ONO. Call me on mobile 0419641071 if interested.
Engine has been fully balanced and blueprinted (assembled by Stone Brothers Racing)
Apex’i PFC with hand controller
Rusic Engineering GTR 4WD controller
Garrett 2560 turbos
Tomei Cam cover Baffles
Oil gallery restrictor
CP forged pistons
ACL race bearings
Eagle forged rods
CP Race ‘Black’ rings
ARP Rod bolts and gudgeons
Balanced crank
Ported and polished head - Fully flow tested
Tomei poncams
Tomei cam gears
Nismo metal head gasket
Nismo water pump
Nismo Oil pump
Tomei fuel rail
Sard 700cc injectors
Sard fuel regulator
Performance Metalcraft race sump (extended pickup)
Tomei 3” induction system
Z32 AFM’s
Pod filters
Tomei Expreme stainless exhaust manifold
Custom side pipe and mounting bracket for track work
Splitfire coilpacks
Modified and strengthened gearbox
Heavy duty single plate organic clutch
Custom engine cover – full engine polishing
Performance Metalcraft air/oil separator
Performance Metalcraft alloy catch can / washer reservoir
Accusump 3qt oil reservoir
Braided engine lines
PWR Engineering custom alloy radiator
Oil cooler – blue line plumbing
Braided stainless brake lines
Stoptech veined race rotors front
DBA 5000 series cross drilled and slotted rear rotors
Stoneshields removed for cooling
Endless race pads (track)
Bosch 500hp external race pump
GTR in tank lifter pump
ARE custom alloy swirl pot and plumbing
Cusco camber adjustment kit – front and rear
Tomei GT coilover suspension
Safety 21 roll cage
4 point race harness attachment points
Turbo timer
Mongoose Alarm system
Auto window lifters
https://www.sau.com.au/forums/topic/268687-r33-gtr-for-sale/
Hi Konrad,
Last dyno was done before the new turbos went on.
At that stage was making around 500hp ATW at 18pounds.
All I can say is it's f*cken quick.
These bigger turbos keep pulling hard at 7500rpm.
  • 3 weeks later...
Yes the car is tuned by Brisbane Turbo & Tuning.
First time I've ever been told it blows white smoke.
We have it running very rich so I blow a shitload of black smoke.
I had it lean out on engine number 2 so it always runs rich as a precaution.
I am more than happy for any inspection on the car it someone wants to buy it.
This would have to be one of the most the most serviced cars around.
It goes for an oil change if ever it goes to the track.
It is inspected for any problems every time.
Repairs, services, replacing parts or upgrading is always when required - not when they can be afforded.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
