hey guys,
got these to offer you.
They are in great condition We also have genuine bride and recaro rails in stock too.
Black Recaro SR3
$1300
Recaro SR3 LHS Seat
Excellent condition
Rail extra
$650 each
BNR34 Seats with Rails
V Spec II
$2350
Bride Brix 1.5 Red
Very good condition no rip
$800 each (ETA July)
Bride Ergo 1.5
2 in stock
$750 each
Bride Brix 1.5
We have rail to suit Skyline and Silvia
$770 each (ETA May)
Genuine Bride Rails R34
$400 Pair
Bride Ergo/Brix Rails for R32/R33
$350
Recaro SR3 Rails for R32/R33
$400
Recaro SR3 Rails for ER34
$400
For more info please call me on 0422 422 344.
Regards,
Thuy
j-imports
https://www.sau.com.au/forums/topic/269101-recarobride-seatsrails-bnr34-seats/
hey thuy. interested in a bride brix 1.5 with r34 passenger side rails. let me know once it comes in. cheers =D
will do mate :P should be in a couple of weeks
interested in Bride Brix 1.5 Red with rails to suit r34. Please let me know when you have them.
damn only have 1 rail for R34 and you both want it?
V Spec II
$2350
Thuy, will gtr34 seats fit into r34 GTT ?
if gtr rails. it wont fit gtt 3/4 bolts will line up except the rear bracket cloest to the door.
you've got a pair posted up. im only interested in the passenger if that helps
i was after both, but i'll find them elsewhere if needed as john was in first
if you're after both seats and both rails. its easier if you grab these. im sure thuy would rahter that than having to find another buyer. im after another bride from QLD anyways.
so wat's gonna happen ? will the seats wobble ? will it even be secure ?
i got r32 gtr seats in my gtt. all skylines from r32 onwards are the same, gtr's and gtst's except for the gtt. got the outter rear bracket chopped off and rewelded in position. works a treat.
could you get some better shots of the black ones.
Also where abouts are you, im probably better off coming and looking.
Edited by deano27
will do when I have them in my hands next week mate :(
We are in Clayton
  • 4 weeks later...
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
