Got these magazines that I wanna get rid of and thought someone might be interested in any of the issues I have...
Asking $5 (Or Nearest Offer) for each magazine.
Autosalon Magazines -
1x Issue 37
1x Issue 38
1x Issue 41
1x Issue 42
1x Issue 43
1x Issue 44
2x Issue 46
2x Issue 51
1x Issue 53
September 2003 Issue.
Fast Fours -
November 2004 issue
October 2005 Issue
November 2005 Issue
December 2005 issue
April 2006 Issue
May 2006 Issue
July 2006 Issue
August 2006 Issue
November 2006 Issue
ZOOM -
Issue No. 88
Issue No. 94
High Performance Imports (HPI) -
Issue 64
Issue 65
Issue 56
Issue 72
Issue 67
Issue 71
Issue 93
Issue 102
Issue 98
Hot4s -
Issue 143
October 2006 Issue
https://www.sau.com.au/forums/topic/269304-magazines/
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
