Kirwan LOL
I lived there for 19+ yrs Cant stand it anymore lol. Have to go back for Chrismas..Im deading the weather and the bogans lol. Last Christmas I was driving around in Dads patrol ute with the aircon cranked haha.
Yeeeeaaah. It's a bitch of a town :banana:
If you don't have aircon in Townsville, life just isn't even worth it lol.
  • Replies 290
LOL I used to have a little sierra jeep (aka Brutis) an no aicon.. SUCKED BALLS. But we could take the top off it and do strand lappys and jump speed bumps hahaha. Park up at the 'D'. good old times hehe.Did u ever do any of that?
My Capri had aircon, and I could also put the roof down. I'll give Townsville this one thing. Convertibles at night are awesome. Nowhere near as much light pollution as other cities, and the temperature is great for it :)
The strand sucked once they built the cop shop, put in the roundabouts, and put in the speed bumps. Although, the car was so low that ANY speed bump in that town sucked nuts. Any driveway too for that matter. :banana:
Aspley is about ten minutes north-west from banyo.
Donna - once my car is registered I'll be up for a north side meet or two. Aspley Baskins isn't a bad idea. There's also Nandos at Carseldine now, and they have a big carpark. Can also keep an eye on the cars there.
I'll think about where else northside would be good. Could even do a Sandgate fish and chips night :banana: it'd look pretty cool with all the skylines parked along the waterfront :)
Morgan!
Well, we can jig the idea around for a bit, then set something up! Would be good as i enjoy coming over to chapel hill but it doesnt always suit weekly!
:P
Maybe we could make the new hot spot Taz's shop! lol lol Dont think there is enough parking ....
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
