  • Replies 290
haha ill pretend i didnt see it.. just means you will have to train harder..
I really wish i could .....
I have a bad back injury, been off work for a year now and only joined the gym about 6 weeks ago and can only do really light stuff, so its not through lack of trying ..... lol lol
Just keep pluggin away ..... :)
Just keep pluggin away ..... :ninja:
well i am i personal trainer and you do know where i work so i can help you..
ill sort ya out no probs.. :)
lmao its hurting now .........
give me a bit longer before you bust my balls .....
all good mate, if you need anything let me know.
so anyways back on topic.
so all confirmed for this friday.. Nandos - cnr beams rd & gympie rd Carseldine, then on too baskins aspley..
hows about 7-30.. gives everyone a bit longer to get sorted after work..
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
