hay man will you send them to QLD and if so do you have a photo of them
sorry man, the postage will cost heaps maybe over 250 bucks, its more of a pic up item due to being a big object.
thanx
thanx
hey mate, you'll find that postage isn't that much, we posted a set of nismo s13 ones through fastways from far north NSW to Melbourne for $70.
just charge the buyer for postage...
hmm, i have discussed already with a gtr owner in wa, and he has tried to find a cheap way but cant, maybe there is maybe not never know, i have a guy lined up for friday, if he doesnt pull through ill post these. my emails [email protected] if you have any questions reguarding gtr parts.
sorry didnt reply to yer pm tommo, cant reply yet not enough post's,
If its still 4 sale im pretty interested, from newcastle and im heading down to sydney hopefully this week if i get my car bak so yer.
Cheers
