post-62930-1242976502_thumb.jpgpost-62930-1242976502_thumb.jpgpost-62930-1242976347_thumb.jpghey all selling my r33 gtst ser 1.5 88 thousand ks cusco coil overs two week old 19 inch fpv rims brand new tyres blitz evryting frontmount exhaust pod full 4in dump pipe back good sterio subs n shit
nice tight lsd. wolf ed ecu high flow t28 makes two eighty ponys at the tyres on 11 pound. turbos new and at r d p the gimp there said will make well over three hundy at the tyres 15 16 psi. just didnt need n e more than whats there so left it. f*kll range of spares az well so if n e one needs n e thing let me know have most parts kits seats diffs mtrs etc?????? joel 0430540512. oh make an offer on the kar cheers its 95 model
https://www.sau.com.au/forums/topic/271269-r33-for-sale/
what language is that written in?
what price range are we looking at here?
trades? also where are you located?
im semi iliterate. one finger typing n stuff. 14 k with heaps of parts rims whole spare kit spare lsd u know lots and lots of spares. it goes good az with more boost and an hour tuning will make two forty rwkws im on the gold coast brought kar from melborne and put the best bits i could find only 88 thousand ks the exhaust is the sik as 4 in all the way threw full adj coil overs the best u kan buy it haz hundy mill adjusment still kan b lower, will put brand new set of tyres all round az well if some one pay 14/ it makes 204kw at the rubber. blows away brand new ss and falcons xrt any way wat may u wana swap? have a spare motor toopost-62930-1243052240_thumb.jpg
https://www.sau.com.au/forums/topic/271269-r33-for-sale/#findComment-4612195
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
