Anyone from around these here parts?
Would be keen for a cruise or a drive.
Also very much interested in getting involved in a motorkhanas or hillclimbs; but from what I know the only motorsport we have, other than going to Brisbane, would be the Grafton hill climb?
Don't you mean ... go for a row... aren't they in the middle of a flood..LOL
hey mate yeh im from ballina way, where bouts are you locate?
they also do track days and super sprints (i think they call them) at ipswitch and warrick raceway.
haha yeh shes abit wet here atm.....
Edited by The Gun
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
