Hey All!!
Gotta clear some room so got some tyres to moove:
Item: 8 x 225.45.17 Continental Sports Contact2
Item: 6 x 215.45.17 Bridgestone Potenza Re 050
Item: 4 x 235.45.17 Bridgestone B530's
Item: 4 x 205.55.16 Bridgestone Turanza ER30
Item: 4 x 205.55.16 Continental Sports Contact2
Website: here
Item Condition: 80+% tread
Reason for Selling: Space
Price and Payment Conditions: 17" for 120pairs 16" for 100 pairs
Extra Info: These have plenty of tread no camber wear
Pictures: if u need em pm email address
Contact Details: pm me or post
https://www.sau.com.au/forums/topic/271442-tyres-inside/
