hey guys my dreams got shattered today after trying to fit these onto my r33 gtst after just buying them at the start of this week. fell in love with the look and the rareness of these wheels! the rears were awesome and they stuck out of the guard just a tad just how i liked but the fronts did not fit due to no clearance for the caliper!!!!!!!!
i got these from jms in adelaide and they told me they came off a r33 skyline so i had no problems but they were obviously wrong and i'm not happy at all!!!! :)
i have to sell them now as i don't want to run spacers or anything. offset is unknown as it doesn't mention anything at all on the rim except for manaray, jwl and size. the rears though seem to be around the +30 mark and front within +38 to +30.
if you are interested bring your car around and we'll test fit the fronts on and if they fit they should be o.k. this is considering you dont have a 33 and have small front brakes. have a feeling they could fit on a soarer or fc pretty well. if you have a r32 i am pretty interested to see if they would fit on the front as they mentioned it would fit a skyline but they might have meant r32 and not r33.
*edit* the rears come with screw on/screw off spacers that actually bolt onto the wheel on the back of where the rim sits on the hub. its just under a cm.
specs are:
front 17x8.5 with crap 245/40R17
rear 17x9.5 with crap 245/45R17
the wheels are old but they are in good condition for the age. if you want show rims these arent it. they have a bit of gutter rash, some scratches but overall very good and still shiney condition. they have the centre caps and everything. give them a bit of a clean and they will look great like what they first looked like when jms got them in the picture. (picture is of the actual rims)
want $850ono and i don't want low ballers cause i love these rims. will swap for anything of interest. need these gone asap so i can get some new rims. pick up in western suburbs of vic or will send interstate but at ur own cost. call/msg me on 0432454387
Edited by jakez88
dude just keep them and run a 15-25mm bolt on spacer, too easy and safe, or even a 5-8mm slip on depending on how far off they are.... or as heaps of people do, file your calipers down a bit, you can take quite a fair bit
i think i might have to run spacers if no one wants to take them off me. gonna have to harden the fk up lol but i'll see how i go with the sale first.
mattysaidso the wheels are at japanese motorsport in adelaide or JMS. the wheels ur after are manaray vr5s but i don't htink they have em anymore.
i'm trying to source out a 20mm bolt on spacer for my fronts and new lug nuts as the standard nuts won't allow me to stick the socket in. clearance is to small. if someone wants them though and for the price i'm asking then i will sell them otherwise my adventure of getting these fitted on the front of my car starts now lol.
pms replied guys. no low ballers please. anyone interested?
i have put the bolt on spacers from the rear to the front and they still dont clear my 33 calipers BUT could most likely clear r32s as there is only a few mm needed to clear. any 32 owners taht are interested and wanting to test fit are welcome.
Edited by jakez88
alrighty these wont fit a r32 as i tried with a friends and didn't fit. need about a 15mm spacer or jsut go 25mm.
measured up as best i could the offset and they seem to be fronts +45 and rears about +38 so definately suitable for a soarer, supra or chaser etc that run high offsets. best to fit up before purchase though.
anyone have a soarer or supra? or if your a hard kunt and wanna run spacers on the front then buy them. $800 guys or throw me an offer.
Edited by jakez88
they wouldn't fit because of the calipers unless you use spacers up front
Edited by jakez88
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
