iv got a jl audio 10w7 sub woofer for sale, its in a custom timber box that is of excellent quality
i bought this around 2 years ago, at the time it retailed for over $1200 not including the box! this is seriously one of the best quality subs you can get, i had this in my r32 and delivered insane bass that was real punchy, if you want the best quality then this is it
used it for around 8 months and has just sat in my room since
this sub is of amazing quality, google it for specs
puts out amazing bass and is extremely sharp
looking for around $800
located in vic, pm me
pics up soon
  • 1 month later...
  • 4 weeks later...
  • 2 months later...
