Hey Guys got the following for sale in South Aus will post wherever at buyers cost
Whole Exhaust for $350 or seperately
3"” Dump & Front Pipe With Split Wastegate Pipe[/font]
$185
3"” High Flow Trust Muffler[/font]
$100
3"” High Flow 500CFM Metal Car
$120
All gauges & holder for $450 or seperately
Drift Iridium 2 Electronic Gauge Boost
$200
Drift Iridium 2 Electronic Gauge Air Fuel
$150
Drift Iridium 2 Electronic Gauge Oil Temp
$100
Gauge Surround
$40
Whole Sound System for $600 or seperately
Kenwood USB MP3 Deck
$150
Kenwood 12” 1500Watt Sub
$100
$100
$100
Sub Box
$40
Clarion 6” Splits
$100
Boost Controller
$20
BOV & Adapter for $70 or seperatly
Blow off Valve
$40
BOV Adapter R33
$40
Will have pics up 2morrow pm for any more details. Happy to do cheaper deals for mutiple items
Thanks Guys
Adam
Edited by r33_crusier
https://www.sau.com.au/forums/topic/272419-r33-r33-parts/
3"" Dump & Front Pipe With Split Wastegate Pipe SOLD
$185
3"" High Flow Trust Muffler[/font]
$100
3"" High Flow 500CFM Metal Car SOLD
$120
$200
$150
$100
Gauge Surround
$40
$150
Kenwood 12" 1500Watt Sub
$100
$100
$100
Sub Box
$40
Clarion 6" Splits
$100
Boost Controller
$20
Blow off Valve
$40
BOV Adapter R33
$40
Thanks Guys
Adam
CAT & Dump SOLD
https://www.sau.com.au/forums/topic/272419-r33-r33-parts/#findComment-4626081
$100
$200
$150
$100
Gauge Surround
$40
$150
$100
$100
$100
Sub Box
$40
Clarion 6" Splits
$100
Boost Controller
$20
Blow off Valve
$40
BOV Adapter R33
$40
Thanks Guys
Adam
Got couple images here, pic of the sub, & the deck and the gagues.
Also the BOV is a HKS SSQV imitation.
Ill get more photos on request
https://www.sau.com.au/forums/topic/272419-r33-r33-parts/#findComment-4628099
Here are some more photos guys
https://www.sau.com.au/forums/topic/272419-r33-r33-parts/#findComment-4628985
3" High Flow Trust Muffler
$100
$200
$150
$100
Gauge Surround
$40
$150
Kenwood 12 1500Watt Sub
$100
$100
Kenwood 12 1000Watt AMP
$150
Sub Box
$40
Clarion 6 Splits
$100
Boost Controller
$20
Blow off Valve
$40
BOV Adapter R33
$40
Here are the pics guys, ill get a pic of the amp eventually. PM me or msg me on 0412 408 342
Thanks Adam
https://www.sau.com.au/forums/topic/272419-r33-r33-parts/#findComment-4629978
$100
$200
$150
$100
Gauge Surround
$40
Kenwood USB MP3 Deck SOLD
$150
$100
$100
Kenwood 12” 1000Watt AMP
$150
Sub Box
$40
Clarion 6” Splits
$100
Boost Controller
$20
Blow off Valve
$40
BOV Adapter R33
$40
Thanks Adam
https://www.sau.com.au/forums/topic/272419-r33-r33-parts/#findComment-4635254
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
