I know they are new, but have to ask if these are fresh tyres or old excess stock?
Some companies buy old excess stock in bulk at lower prices and bring em in that way...
I bought them for my car last month. But then I realised I should have got 235s, hence I'm selling them.. Ku36s only came out recently, so they are fresh tyres.
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
