$1000 for nistune? you could buy the chip, license, wideband and get installed and tune it yourself for far less than that.
s15 sr20 injectors go straight in and flow enough for a highflow
  • Replies 43
  • 4 years later...
my skyline r33 gtst series 1 with stock ecu, stock injector, stock afm, stock intercooler just a 3inch turbo back exhaust and avcr (boost controller) was putting out 286rwhp (215rwkw) on 11psi (0.75), I was repairing some idle issues so didn't test on 0.9bar (13.5ish psi max id personally run in cool weather) or 0.5bar (7.25psi ish), that was with dirty injectors hence the rough idle,( note pinching the fuel return hose to increase fuel pressure diagnosed this), so I guess its putting out a bit more now, fuel consumption is 12.5ltrs per 100km 50% plus cruising maybe 14ltr/100km hard/cold/short drives, did need oil catch can as oil was getting sucked through air recirculation line, it does however seem to have an almost unnoticeable flat spot at 5-6000rpm (rnr?), new spark plugs, bkr6's almost eliminated this. either way with good oil and safe operating temps im sure 11psi on highflow is safe enough for day to day travel, (almost unnoticeable fuel increase) I have a safc that came with the car it might help extract more power???? will inform if I bother to put it on. to note motorbike cant pass in drag, only car to beat so far was an evo ??? power??? dunno.... wanna know more 0404 919 450
Have a quick ready of my thread. It contains pretty much all the information you require to know. The page is indexed and linked from page 1. So go to page 1, pressure Ctrl+F and type in 21U for pages contain details of R33 Rb25det high flow, or OP6 for pages contain details of R34 Rb25det Neo high flow.
http://www.sau.com.au/forums/topic/261613-hypergear-hiflow-service-continued/
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
