Hey mate
I have a R32 GTR shell ( no engine , g/box, seats ) most the other stuff is there ( has suspension, rear cradle and diff, windows, back seats, wiring, all trims and so on ) Its not rego's or complied , its silver, 1991 model i think will confirm that.
Chasing $5000 for it
Im in Adelaide
https://www.sau.com.au/forums/topic/273582-r-32-shell/#findComment-4641416
Hey mate
Im in Adelaide
thanks for the offer mate a little far away and really only need a shell to replace my bent one thanks anyway
https://www.sau.com.au/forums/topic/273582-r-32-shell/#findComment-4641429
mainly just sill and bottom of the rear quarters... the shell itself is pretty straight etc it was a drivable car
all depends what you need with the shell... take it to pm
sorry mate cant pm yet but working on it
https://www.sau.com.au/forums/topic/273582-r-32-shell/#findComment-4641505
still looking
Hi Matt
Sorry for taking a while to get back to you I have been just trying to work out he best way to go with the car as there have been a couple of options and a few different people asking.
If you are keen how quick would you like to move.
So I can give you a price please confirm what parts you require and optional. From out phone conversation you mentioned the below, please advise if I missed anything
Shell including
Front & rear windows & side windows
Brakes & hubs
(Brake Master Cylinder?)
Rear Cradle
Optional
Doors
Boot?
Tail lights
Regards Taylor 0408188777
https://www.sau.com.au/forums/topic/273582-r-32-shell/#findComment-4689408
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
