does anyone know whats the max time you can get your car detailed/polished per year without damaging your paint etc? ive got mine detailed 4 times since oct last year.
who did you go with for detailing here?
Washed the car for the first time after the detail. (Damn rain has been keeping me from doing this)
What a difference a detail makes to the ease of cleaning the car.
The dirt wipes right off the top, easy.
I didnt even realise how dirty the car was until i washed it, i guess i was used to it looking dull.
Another plus for having the car detailed, washes are now very easy.
And it looks the same as it did when mark did it, meaning the products are really doing their job.
i agree on that.
hes making good investments on those polish and wax he uses eh...
well you dont get that kinda value for money in brisbane...
costs more than $350 for inside and out here.
HAAAH ?!? What a rip ouch!
When i used to do mobile detailing, i'd charge ~$250 for in and out.
After the detail, the best thing you can do is look up ways to wash the car properly (ie washing without scratching. There's a couple of Aussie forums dedicated to detailing if you google.
He charged me $350 for about 6 hours work, no inside work. I told him he was recommended by Dr.Detail who did someones black v35 for $350 inside and out, and he said he cant do that. He said he would have to charge more if he did more work on the outside so i just got $350 worth.
If you've got a silver car, i wouldnt recommend it or try someone else who is a bit cheaper.
Edited by Eldubb
