I did, but then i sent them off to get flow checked and cleaned and the pricks threw out the boxes.
It was the same part number listed on google etc. I think slide sells them on here under the traders, the part number should be listed there.
hi Ian, the part number should be 63587
サイズ
(流量) タイプ 抵抗 噴霧孔数 カプラー色 カプラー形状 商品コード
530cc TOP 高(High) 4 Pale Blue 楕円 63590
650cc TOP 高(High) 2 Yellow 楕円 63586
800cc TOP 高(High) 2 Purple 楕円 63587
hope this help.
that's the problem it's not :) basicly the injectors not pulsing etc had all the settings right on the PFC 1.6mlag time etc, my tuner even called some people on the mainland to see if he was doing anything wrong but they said it was spot on, So he thinks i might have the wrong impedance injectors ?
that's the problem it's not :whistling: basicly the injectors not pulsing etc had all the settings right on the PFC 1.6mlag time etc, my tuner even called some people on the mainland to see if he was doing anything wrong but they said it was spot on, So he thinks i might have the wrong impedance injectors ?
Does the car run? Or dont any of the injectors pulse?
Its pretty common for injectors to "stick" if they have been sitting around for a while. My brother has some 850cc denso's and the car was rough, sounded like only 5 cylinders were firing. Got a screw driver and gave the injectors a gentle tap and it was fixed. Its quite funny to see, and it seems dodgy, but thats all they need.
Or you could be right, that little ridge might been its a totally difference injector, but i doubt sard would make an injector that shared the same colour and shape and have different impedance. Have a scan through all the sard injectors and see if there are anyother top feed purple injectors.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
