just sent my car in to have it stereo finally put in. below is what going inside.imnot good with model nubers so ill post them here later.
the New Elipse all in one DVD deck.
Eclipse 6" splits
eclipse 6" rears
2 4channel fusion powerplant amps (500RMS each) Speakers
2 2 channel fusion powerplant amps (580rms each) Subs
2 12" fusion powerplant subs. in a fibre galssed boot.
2 2 faren capacitors
2 head rest screens 5 1/4"
shit load of sound dedener.
i think thats everything.
the boot is getting a custom mold (no spare tyre). fusion green
i'll conferm all the power outputs and model numbers sometime this week. dont pick if there rong.
ill get some progress pics and the final product when done. notice the key word "when"lol
https://www.sau.com.au/forums/topic/27683-new-stereo-pics-when-finished/
I am not trying to have a go at anyone, but I just have not seen fusion perform. If its the right price yeah go for it. I am not at all trying to say i have the best stereo around, no where near it, but for example, the Fusion WRX just made 140 db with 3 15's and a hell of a lot of power at the 2003 jamboree. I would have thought it may have performed a little better.
My car got 148 db with two 12's at jamboree, and i had a few bugs that i have been iorning out.
Honestly good luck man, i hope it all works out!
Happy Stereo-ing
well its everyone to their own .. its their car so they can do what they like .. i agree that fusion is probably not the best for power and spl and even sq for that matter ... but u gotta agree that their green aliens are pretty cool :) .. but yeah in car audio theres always something thats better than something else ... if u really wanted some power u'd try and get some adires and all these other american brands u've never heard off ... well i can't wait to see this install ... should should kick my pissy diy install :(
Originally posted by Fhrx
Should sound nice. :wave:
Why two caps though?
I thought you need 1 farad per 1000wrms. that setup is around 2000 wrms looking at the amps (580x2 + 500x2 = 2160wrms) thats a lot of power. I'm running an mtx amp with a 0.5 farad cap, no diming lights! :cheers:
Sorry if i offended or pissed anyone off. Just saw he was using eclipse hu and splits and thought must be goin sq setup, that's why i was kind of curious about why the fusion gear?
the fusion 12" powerplants perform really well if your after nice booming bass. i aint going for spl as my box wont be ported im just going for a big bass (if that makes sence). the eclipse splits and rear six inch's will compensate for the sq. sq is my first priority as it is a dvd deck. i'll be in adelide a few weeks after its finished and in warnambull next weekend (if its finished) so if anyone want to see give us a pm.
my ford has a 1 12" powerplant in it and i was quite happy with the results i got from that. 133db. ported box though.
i might of forgot to mention it before but dont quote me on the outputs and stuff. as for the caps.... 1 per sub will make sure it hits hard and strong first time and every time. ill get the exact specs hopefully to you today but most likely not until sometime next week. :cheers:
Originally posted by Evil
I thought you need 1 farad per 1000wrms. that setup is around 2000 wrms looking at the amps (580x2 + 500x2 = 2160wrms) thats a lot of power. I'm running an mtx amp with a 0.5 farad cap, no diming lights! :(
With all due respect, dimming lights are a sign of bad system wiring and caps are a band-aid fix for a bigger problem.
Before you start buying caps, you need to have a good look at the wiring in the system. Then take a look at the charging system and power storage. If there is a problem, upgrade the battery and alternator before buying a cap. :P
You're right. But there was no dimming before the cap. It was just added just in case and the battery although not deep cycle is not standard. Some people with yellow tops and upgraded alts still run caps. Dimming lights are a bad sign but it doesn't happen to me :D All the wiring in my car is perfect (I've had a lot of practice) and also the wires are nice and short. Caps are only a band aid if you are having problems with dimming light before you fit 'em. But you are right if you are having electrical problems then look into the other parts first. A cap may not even help!
  • 5 weeks later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
