just an EOI at this stage as latey iv been thinking about getting a 4 door car. most likely a V8.
price im after is 20K with rego and RWC.
Basic details are:
1998 R34 GTT 2 door coupe
manual
white
180000
Modifications are:
GCG high flow turbo (set to 15psi daily) no shaft play at all on turbo
480cc injectors
HKS exhaust cam gears
Walbro fuel pump
3" turbo back exhaust
FMIC
Z32 AFM
Apexi PFC
Racing Logic coilovers
car has the basic mods already done as listed. car is tuned for a safe daily run putting out 236rwkw (tuned by Ray at RE customs).
car is serviced every 5000kms by RE customs also so service history can be provided. car is running great with only one thing needed is the stock clutch to be replaced, which for the asking price will be replaced with brand new Exedy clutch.
car is clean and straight. never been in an accident. looks nice and stock from the outside. cooler is painted black to avoid getting any extra unwanted attention.
dont have any recent pics of the car (everything is the same except now its on black 17" AVS wheels)
feel free to throw in any reasonable offer. can can also be sold stock.
ALSO IF YOU HAVE SOMETHING THAT WOULD INTERST ME FEEL FREE TO PM. WOULD BE VERY KEEN ON A MANUAL V8. but if you have smoething else as long as its not anything older then 04 drop me a pm
ta
Ash
https://www.sau.com.au/forums/topic/276944-eoi-melb-1999-r34-gtt-manual/
sorry guys didnt get a chance of cleaning the car and posting new pics up. will do during the weekend.
also forgot to mention it also has Nismo 300kmph dash.
atm im looking at getting new clutch put in within the next 3-4 weeks.
like i said its an EOI but im looking at offers over $20000. only way ill consider less is if i return the car to stock. so please dont offer me anything below $20000 for the car as it is cause i will say no.
like i said im in no rush to sell. i love this car very much and not that keen in selling unless i get a good offer for it and i find something i like.
so ye
ta
Ash.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
