  • Replies 147
Posted Images
LOL that little Nissan that you start out with is awesome!!! I'm pumping out 300+ kw on it :thumbsup: Stroke it out to 2.1Litres, throw in some cams, get it breathing, do a turbo conversion on it (I've only gone with the sports turbo thus far), throw in a roll cage, buddy club P1's wrapped in some decent compound, and most importantly AWD DRIVETRAIN CONVERSION! Once I discovered the Drivetrain conversion that was it! Makes for an awesome car! Still understeers a bit but nowhere near as bad as FWD! You can still get it sideways though with the AWD despite its tendency to understeer, in fact I got the drifter achievement in it :P But yes, the thing friggin LAUNCHES!! I've got the level 1 brakes at the moment, needs more stopping power though... LSD was a must, just went with a 1.5 way. But yes, with it stroked out, blown, bigger cams, upgraded pistons.. that little Nissan is soooo damn quick! Oh and transmission! Didn't go as far as a racing transmission, just the sports one and it smashes through the gears quick enough.
Anyhow, I think 4 hours is enough Forza 3 for the night haha Definitely worth buying!! Night all :(
https://www.sau.com.au/forums/topic/277410-forza-3/page/4/#findComment-4895360
Oh and by launches, I mean it does 0-97km/hr in little of 3 seconds :P It has been gutted though... BUT there's still a decent amount of power left to unlock in it..just need to do more races to get cash :thumbsup:
https://www.sau.com.au/forums/topic/277410-forza-3/page/4/#findComment-4895365
lol, I farked that little piece of shit off quick smart! Bought myself an oldschool Fairlady Z, dropped in an RB26, AWD, lightened it, did brakes, gear box, suspension, 255s all around etc, still have most of the power to unlock.
That thing RIPS (lol) past supras, skylines etc, raped the b class turbo races. Needs a little bit more power to keep an AWD slide going through a corner, at the moment, I'm having to smash 2nd, then down it to 1st in the last bit of the corner.
smashed 370Zs etc too in the fairlady tournament!
That car was my baby in the last game and I'm SO GLAD they included it! :P
I also love how every car is automatically unlocked at the start of the race, you just need the money!
also, that rewind feature is awesome, even though I keep forgetting about it, I only use it if some bugger brakes infront of me and I 'orange' my engine :thumbsup:
https://www.sau.com.au/forums/topic/277410-forza-3/page/4/#findComment-4895613
The only thing I don't like is the artificial slow down on the tracks with the speed bumps instead of sand traps. How am I supposed to be all awesome and flip my car and shit if they go and do that?
I lul'd at myself being in the top 1% for F and E class, what does that even mean?
https://www.sau.com.au/forums/topic/277410-forza-3/page/4/#findComment-4895645
I rarely buy cars in Forza because generally I buy one then win the same one on the next race/level so I have used the Fiesta, 500, Brera and Focus RS so far.
How sweet is the Collectors Ed. though? I've picked up a few special addition type games over time but F3 I think, simple but impressive not just a map and some plastic crap.
https://www.sau.com.au/forums/topic/277410-forza-3/page/4/#findComment-4895655
How big is the memory stick that came with it? I just got a free 8Gb one yesterday so it was a bit unnecesary, and I don't think I'll be using the keyring :thumbsup:
Nice though, and the box is top notch n shit.
I HAD to buy that car (it was only like 5000cr) cause I know how awesome it can be! I was sick of all the little square boxes I was winning.
https://www.sau.com.au/forums/topic/277410-forza-3/page/4/#findComment-4895675
any of you boys dabled with the drift mode yet, namingly fujimi kaido track?? im after some honest opinions from car enthusiests not 12 yrold gamer kids lol. like can you do slit screen on the above track, so my brother and i can f**k around on it in the same room or does it all have to be online??
i was gonna go pick up a 360 today with forza and put a pre order down on the new gta and l4d2.
https://www.sau.com.au/forums/topic/277410-forza-3/page/4/#findComment-4895749
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
