Item: Veilside 5 spoke 3 piece wheels with Bald Tyres
Item Condition: Decent, need a polish/lip machined, one wheel has a few flat spots(bout $150 to fix, Still holds air just fine) Tyres are bald
Reason for Selling: Got 18's
Price and Payment Conditions: CASH OFFERS OVER $400 or swap for Intercooler kit for R32 GTST.
Extra Info: Cost over 3k new 7.5 inch wide front, +23 Offset 8.5 inch wide rear, +41 Offset 235/45 tyres 5x114.3 stud pattern Comes complete with centre caps aswell
Pics are in this thread
http://www.boostcruising.com/forums/index....=433089&hl=
These are pick up only!
Contact me on 0400641699 or pm me
Cheers
https://www.sau.com.au/forums/topic/278045-veilside-17s-5x1143/
