Make/Model: R31 GX Skyline
Year: 1987
Kilometers: 221,300km (engine only 75,000km)
Transmission type: R33 Auto (Stage II shift kit)
Engine: RB25DET
Colour: White
Modifications: Where do I start...
ENGINE - RB25DET engine conversion - Saber FMIC - Custom 3" mandrel bent exhaust with 4" steel cat and 2 hi-flow mufflers (quiet) - pod filter - Turbotech boost controller - 195rwkw on 10 psi (now running 12psi - not dyno'd but tune is safe) - Davies Craig 16" Thermofan - Engine using Penrite SIN fully synthetic oil - Gates performance timing belt repacled on install with new NGK spark plugs
GEARBOX - R33 Auto with M.V Autos Stage II shift kit with B&M Quicksilver ratchet shifter & Davies Craig trans cooler - Using Shell Donax TX fully synthetic oil
BRAKES/SUSPENSION - R33 front rotor and calipers with Garage7 custom adaptors and hubs - Whiteline swaybars front and rear - Pedders heavy duty springs (standard height) - Using AP600 racing brake fluid
WHEELS/TYRES - Performance 16x7 (+20) wheels with Sumitomo HTR-Z 225/50s (95% tread)
EXTERIOR/INTERIOR - Custom made S1/2/3 front bar - S3 taillight conversion - very straight, no rust and excellent paint - tinted windows - S3 electric mirrors - 2009 Hyundai Elantra head unit with Clarion 6" (front) Clarion 6x9" (rear) - Saber electronic boost gauge - Dash modded for low fuel warning lamp - interior very clean and tidy - Rhino RAM security system with2-way GSM communication - central locking
Accident History: None known of
Asking Price: $7,500 - firm
Contact Details: PM - [email protected] - 0408 696 307
Other Comments: This car has been a meticulous build with great attention to quality and only the best products have been used. Has only travelled 5000km since engine swap. Comes with mini-spooled rear end (requires bearings) and 5-speed conversion (requires attention to 2nd gear synchro) all the standard suspension parts
Will consider swaps but the price is firm... if you can do it cheaper to this quality then knock yourself out! Tyre kickers and test pilots and lowballers click HERE.
Can also supply LinkPlus ECU installed and tuned at additional cost...
If you are a member of r31skylineclub then the build can be seen here... http://forum.r31skylineclub.com/index.php?topic=120872.0
  • 2 months later...
Car is back on the market - now has a Walbro 500hp fuel pump in tank, LinkPLUS engine management and tuned to 290kw on 13 psi.
Negotiable on $7000 - comes with a bounty of parts & spares
dyno sheet for 290kw??? love to see this
290kw At the flywheel
Made 195rwkw with a 5 speed - then made 148rwkw with auto box with no other mods - therefore its taking 47kw to drive the auto. Dyno sheets confirm.
After tuning it made a 53rwkw gain, so using Powerun's script here http://www.dyno-power-run.com/dynocalc.shtml it works out to be 288kw at the flywheel.
Disagree with the calculations... take it up with Dynorun :D
  • 2 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
