hey guys need all this stuff gone,
1. sniper nos set up, comes with everything you need, all wires, brakets, bottle, 50hp-75hp-100hp jets! had 100hp shot in my 34 added like a extra 70rwkw! only went though a few bottles so the set up is pretty much new! also comes with a presser gauge, and a RPM activated switch which allows you to insert different pills to choose at what rpm the nos comes in and what rpm it stops. Its great to have so you get the most out of it! was all installed by trent at status tuning! Im looking for around $650!
2. Nardi steering wheel with r34 boss kit $200
3. R34 gt/gtt tiptronic 4 speed auto gear box. comes with tail shaft, clutch plate, tirtronic gear stick and interior bit that goes around $600
4. R34 auto cluster $200
pm me or give me a call, 0433467819! pick up only im in vic, hallam
anyone need this stuff out of here! price drop nos kit $550, trans and everything $500. will sell tran by its self for $300! cheers
  • 5 months later...
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
