hey guys has anyone had their standard ecu tuned at ECUTEK or anywhere else..
or is it a waste of time. and whats the big difference between standalones and piggybacks..
dont make fun of me im only new to this stuff :P
https://www.sau.com.au/forums/topic/279458-standard-ecu-tuning/
