Originally posted by BY BY
Gerds,
I can get a you nice set of Advan copies for you which do fit a skylines offset. They are available in silver, chrome or black shadow chrome.
pm me for info
Available in 17's,18's or 19's
Nick
Would the 18's or 19's fit a 33 GTST? how much do you think this would come up to with tyres?
https://www.sau.com.au/forums/topic/2811-roh-shadow-chromes/#findComment-50093
25GTT: yeah 18's and 19's will fit. 19's particularly will depend on how low your car is and what width rim you get.
I have seen a white R33 with 19 inch bronze versions of these advans as seen below and it looked wild
http://www.nismo.com.au/morepics%203/advan.jpg
I think 19's with rubber are around $3500
I would expect the 18's with rubber you'd be looking around $2600
https://www.sau.com.au/forums/topic/2811-roh-shadow-chromes/#findComment-50106
Gerds,
I have a set of ROH Adrenelin Shadow Chrome's on my R33. When I emailed ROH for a set of lock nuts they told me they don't make those mags to fit skylines. But Bob jane showed me the catalogue for the lock nuts which listed R33 GTS25t as a model and the nuts fit perfectly.... Weird.
I'm not sure of the offset cause they came with the car.
Here's a pic..
https://www.sau.com.au/forums/topic/2811-roh-shadow-chromes/#findComment-50243
By BY: Cheers dude, but I'm looking at the blitz rims in the for sale section and drooling atm.....
Gerds,
I got the rims with the car, they are 17's, I think they are 8"s all round. My brother in law is looking at a set of 16's for his lancer and BJanes quoted $340 per rim for them, so I'm thinking 17's would be around the $400 mark??
https://www.sau.com.au/forums/topic/2811-roh-shadow-chromes/#findComment-50614
Guest Crazyfcuk
ive got the same mags as evl r33 on my line (and number plate - not on purpose). Mines a na tho, not sure if its any different.
go to www.cardomain.com/id/crazyfcuk theres a photo of them there.
They are quite narrow tho, mine are 18x7 tried to get 18x8 but they were sold out and not getting anymore in.
i paid 3000 for mine with kumho tires
https://www.sau.com.au/forums/topic/2811-roh-shadow-chromes/#findComment-51589
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
