Item: Power fc
Age: second hand
Condition: great
Price: $1000 delivered
To Fit: GTR
Contact: pm or 0431 520 274 (Thomas)
Comments: Used in my R32 GTR for approximately a year, was tuned with stock turbos for Nth QLD @ just under 240kw with a very safe tune. Upgrading to link
Controller; FCC3 020-22027
Model serial no; GTR33L 020-2306
Item: Black AVCR
Age: second hand
Condition: pretty much as new
Price: $550 delivered
To Fit: yours
Comments: Comes with everything that you need to fit. Selling it because Im using the gate to control boost.
No pics atm, my phone's sd card is playing up.. Will have to wait until I can borrow a friends camera. Or I can mms any photos to your phone.
Edited by Tomek
https://www.sau.com.au/forums/topic/281395-power-fc-black-avcr/
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
