hey people just putting the cefiro up forsale as i have just finished building her and have lost my licence for 2 years, so its really a waste for me, Im looking for a cheap track car plus cash my way or something similar. I want to get out of debt as i have no job atm.
Ive owned the car about 2 years (only been on road 6 months).
The Specs follow:
A31 ceffy Resprayed Canary Yellow with small amount of glitter flake with black bonnet and mirrors
unsure of what kit it is maybe someone can enlighten me
ENGINE:
RB25/30 n/a bottom end , re-coed head with 3 angle valve grind, new valve stem seals, new headgaskets/seals all round, ARP head stud kit.
ECU:
Microtech lt10s with export ignigter to suit coil pack, hand controller for microtech.
TURBO/EXHAUST:
Highmount manifold KKK-27 Turbocharger approx- Ar60 f/c .82 exausht housing. GT30 flange 3" dump pipe to 3" out the side skirt flange midway will put full exausht on upon sale, Turbosmart 35mm ultragate? with new gate spring to screamer pipe.
WHEELS:
RJ 18x8 all round silver/Chrome lip 30mm bolt-on rear spacers.
SUSPENSION:
Tein Coilovers front and rear
Camber tops
Cusco Front strut brace
Castor rods
Solid cradle bushes(no rubber complety solid)
Locker diff 5 bolt unsure if its a 33 rear cradle as has all 33 running gear on it.
MODIFICATIONS:
Skyline 5 stud front brake/hub assembly conversion
Front mount
New NPC 5 Puck buttun clutch rated 500HP DRIFT/DRAG Machined flywheel
Polished inlet manifold with rb25 throttle body
Anodised fuel rail with -6 speedflow fittings
Polished Fuel regulator
650CC Rochester injectors
040 fuel pump
Surge Tank fuel system in boot of car all speed flow fittings.
EF falcon coil pack with eagle 8.0mm leads
New plugs
New water pump
new timimg belt/pully
Oil catch can
remote oil filter relocator All speedflow fittings/braided lines
Annoidised oil cooler mounted behind grill
Turbosmart blow off valve
Nardi steering wheel
Recaro Reclinable bucket seat Driver
Maybe a few other little things here and there i have fogotten.
Have dyno sheet available, The car will be sold unregistered possibly with rwc.
Have 4 pairs of skid rims for it, Along with 2 litres of the same 2 pac yellow paint for any damages touch up's. also dont have the rear spacers on in the photo i need new wheel studs, on one side.
car will at this friday drift prac if anyone interested in checking it out then.
car is located sth side brisbane,
$15000 or let me know what you got!
pic's---- http://img43.imageshack.us/gal.php?g=rolla180ceffy003.jpg
http://www.flickr.com/photos/chasemontesal...57621632690729/
0401359158 or pm
https://www.sau.com.au/forums/topic/281690-a31-cefiro-rb30det-351rwhp-14-psi/
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
