Hi guys,
Well its come time to get rid of my baby. I've owned it for about 4 1/2 years now and have completed all the upgrades, paint work etc myself as I'm a fully qualified spray painter and have been around the car scene for ever. Its a '93 R32 GTS-T completely resprayed about 2yrs ago in bayside blue. I'm selling because my partner and I bought a house. The car has slight panel damage but nothing unrepairable. I'll try and remember everything but any questions PM me please.
Engine:
Standard internals
HKS 2540 B/B turbo (approx 20k's)
R32 GTR injectors with ballast resistor
Apexi Power FC w/ hand controller and optional boost controller
K&N air filter
Trust intercooler
Splitfire coil packs
Bosch 040 intank pump
Nismo rising rate fuel reg
Turbosmart Blow-off valve
Drivetrain:
Standard 5 speed with H/D Extreme clutch
Standard viscous diff
Suspension:
ISC N1 Coilovers (5000km)
Adjustable upper rear control arms
HICAS lock bar with lines removed
New ball joints, rack ends, tie rod ends, numerous bushes
Interior:
Standard interior
Metallic red inserts
Boost gauge
Air/Fuel ratio gauge
Oil pressure gauge
Aftermarket wheel and gear knob
ICE:
JVC Cd player w/ USB
Clarion 4 channel amp
Clarion 6*9's (rear) and Clarion 6 inch splits (front)
Exterior:
Professional respray in Bayside blue
GTR bonnet & Grill
Jetspeed rear pods
Jetspeed side skirts
Bob Jane 18*8 5 spoke rims w/ Federal 235/45/18 tyres (50% tread)
Spares:
Rb20 DE gearbox
diff
assorted suspension parts
Jetspeed front bar (fibreglass)
Plus more !!!
The car is currently registered till November 09, I'm located on the NSW south coast in Nowra. I'm also having problems with my uploading of photo's so if anyone wants em just send me a PM with your e-mail address and i'll send em to ya.
Asking price is $9500 ono as is or $10500 with panel damage fixed. Also i'm open to offers and cash my way.
https://www.sau.com.au/forums/topic/283321-bayside-blue-r32/
  • 3 weeks later...
  • 1 year later...
Peeps,
My car is back up for sale as I've acquired another project and need the Skyline gone. $7,000 cash firm. Will fix the dent in the rear drivers quarter. Also comes with a RWC as its outta rego in November but can put rego on it for an extra $500. It now has new Sard injectors and also some F$%k head stole the GTR grill.
Call me on 0405144982 please no time wasters. Need it gone people.
Will get some of the inside and engine bay hopefully tomorrow. To be totally honest its a little rough with the bent front guard (have spare in perfect condition) and a few scratches here and there but for the bolt ons and how it drives plus what others are asking, its definately worth a look. Also the plates no longer are on the car but are still available at the RTA.
Oh its also got clear indicator now too. Its got 195,000km
Edited by Drift Freak
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
