All these parts came out of a series 2 R33 GTS non turbo.
Stock (N/A) muffler = $65
Stock gear knob = $50
Stock series 2 carpet set = $140
Stock front rotors = $80
Stock boot board = $30
Stock boot carpet = $30
Sony headunit CDX-GT270 = $80
Pioneer 3 way 220W speakers TS-A1672S= $40
Prefer pick up but can post at buyer's expense.
Can contact me on 0434 502 855
It's in pretty good condition, with normal wear and tear, you can still easily see the numbers and the H pattern.
Had 50,000km on the clock when I pulled it off.
Floor mats = SOLD
Pioneer speakers = SOLD
Still for sale:
Stock muffler = $60
Stock front rotors = $70
Sony headunit CDX-GT270 = $75
What sub are you in??
looking at rotors are they warped or miss shaped? do they need machining?
PM Sent
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
