hey guys i have only had the car for about 5 months being the second owner in Aus it's been a great and fun car but I am not in a hurry to sell.
car is extremely quick
triptronic
6a13tt motor
AYC - just serviced
timing belt done in japan
car has 139,xxxkm on it i purchased it with these modifications
Greddy front mount Intercooler
full fujitsubo exhaust (turbos back)
tien ha coilovers
mines chipped rom
apexi boost gauge
greddy profec b boost controller
I have added \ replaced
evo 7 17 x 8 with about 80% tyres
rolled guards
BMC air filter
Evolution 8 brembos front and back with endless pads
retrim back seats in leather and suede
door trims retrimed in black suede
IFS sensor replaced
spark plugs replaced
top gun leads
Crank angle sensor replaced
and torque converter seal replaced + motul atf1a fluid
car has a few scratches and tics in the bumper thats all thats wrong
$14,500 :down:
car has rego till jan
cheers
0402670354
https://www.sau.com.au/forums/topic/284791-fs-1998-legnum-white-modded/
hey mate i have not had the car dynoed but looking at the 170-180atw mark
and car runs great as it should :P
That's a pretty decent gain mate.
I was just wondering as I had a Galant a few cars ago. I was going to modify it, but after doing some research I found out the ecu was pretty anal. Most other people gained fuel mixture problems. Then again mine was a 2000 model, and in the later models the emissions were much more strict.
Anyway you have done the hard yards if it's running well. Somebody buy this if they want a good Legnum!
  • 1 month later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
