FS: Starlet GT
Starlet GT built 9/90
Silver in colour
92 000ks
ABS
Full stainless steel exhaust system with an Apexi muffler
Koni yellow adjustable shocks
Custom air intake with HKS pod filter
Hi-flow turbo
Very clean inside and out.
Pioneer CD player
Autometer boost gauge
12 months rego
$12 000 negotiable
Contact on 0416 188 504 or [email protected]
https://www.sau.com.au/forums/topic/28486-starlet-gt/
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
