Wanted: R33 Series 1 Drivers Side Window Control Unit And Plastic Arm Rest It Sits In...
Hi.....
Im after an R33 series 1 drivers side window control unit plus the plastic arm rest you lift up to get to it....
(has to be series 1 as series 2 plug is different)
In good condtion please. Im in NSW 2456.
PM me with price including postage and a photo if possible.
Thanx............
Liz
    • Well, this, but braided line to the sender that is mounted on the chassis. Oil Pressure doesn't need to be close, while I prefer Oil Temp is in the active oil flow (bro science, not sure how much it matters).  That's how I've had mine set up for years and it works OK
    • Welcome back! There is a v series forum, a little quiet at times but every new active member helps
    • But, per MBS206's question, what happens when it doesn't start. When you turn the key to IGN, do the dash lights come on (then go off after a couple of seconds) - likely alarm or other electrical issue When you turn the key to STRT do you head a clear click (the starter solenoid trying) without the engine turning (likely starter motor)
