R33 Apexi Carbon Strut Brace, Rb25 480cc Injectors, Ase Rb Fmic Kit, Recaro Sr3, Kts Swaybars, Kts Castor Rods, Greddy Oil Cooler Kit, Apexi Tt
I have decided to combine and update this post as people were having trouble seeing whats sold and available in the last.
Well the car is finally almost finished after 12 months of chopping and changing my modifications so its time to have a final clearout so the following is for sale.
All parts are in Adelaide but happy to package and post or courier as needed at buyers expense.
Please either PM or SMS 0404998591 as I cannot answer my phone when at work. Please SMS and I will call you back when possible if needed
Rare R33 Apexi Carbon Fibre Strut Brace in excellent condition weighs next to nothing yet extremely strong. Looks awesome installed the red matches any speedflow fittings you have fitted. Price - $200
ASE, Autosport Engineering, RB FMIC Kit in excellent condition complete with mounting brackets, piping, silicon joiners, clamps, bolts etc. The core is 78mm or 80mm thick from memory Price - $280
6 x 480cc S15 Injectors complete in RB25 fuel rail in excellent condition, cleaned less than 5000kms ago, and good for 270-280+rwkw. Injectors have only just been removed and are still in a wet rail ready to bolt straight on. Price - $450
Mint Genuine Recaro SR3 Reclinable Race Seat complete with genuine base frame ready to bolt into R32 R33 R34 Cefiro and with a small bracket these would fit S13-S14. As the seats are Recaro complete with Recaro Base Frames I have had no problems with defects and these seats having rolled through regency with them. Price - $500 FIRM
R33 Cusco Brake Master Stopper complete with installation bolts. The stopper is missing the disc bit at the end but I just used a 10 cent piece which worked perfectly. Made a huge difference in braking performance and pedal feel. Price - $50
Japanese KTS Front and Rear Aftermarket Swaybars originally off a R34 GT-T but fitted my R33 GTS-T perfectly complete with recently fitted new SuperPro D Bushes on the front bar and new SuperPro end link bushes on the rear (sorry forgot to photo the end links but are included). The bars are 27mm Front and 22mm Rear. Price - $300 FIRM Pair
Japanese KTS Castor Rods to suit R33 R34 S14 S15 in excellent condition. Price - $200
Brand New in box Greddy Oil Cooler Kit to suit R33GTR / GTS-T + many other. Price - $675
Brand New in box Attain HICAS Lockbar high quality solid Japanese HICAS Lockbar perfectly safe unlike the many cheaper unsafe/flexing china spec ones. Price - $175
3" RB Stainless Front Pipe - suit RB20/RB25 complete with gearbox mounting bracket. Price - $100
Apexi Pen Turbo Timer as new complete in box bought from Autobarn and as such has english manuals aswell as jap. Price - $100 Delivered
Front Pair of Cusco Pillow Ball Upper Mounts to suit R32 R33 R34 & C34. The mounts are complete in box with manuals etc having only been trial fitted before changing suspension setup for the third time. The Cusco pillow ball upper mounts enable improved steering performance, stability and braking. Features: Controls unwated forces during acceleration, braking and cornering +
Improves steering response and performance, increasing stability during turn in and braking. Price - $200 (These are $353 from Nengun)
Location - Adelaide but happy to post interstate at buyers expense
Contact - PM or SMS 0404998591 as I cannot answer my phone when at work. Please SMS and I will call you back when possible if needed
Edited by nigelswazi
The following is now confirmed sold
KTS Swaybars
All other parts are still for sale
S15 480CC Injectors + ASE FMIC + KTS Castor Rods are sold pending payment and pickup Saturday
Parts Remaining:
R33 Drivers Recaro
ATTAIN HICAS Lockbar
3" RB Front Pipe
Cusco Pillow Tops to suit R32 R33 R34 & C34
  • 3 weeks later...
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
