Hi, repair on my gtr is just about under way, just need a few more bits like, set of indicators and for another project a stock or chipped R32gtr ecu that may allow for oversized injectors, cheers Damo
hey i have a r32 gtr ecu it has j speed sticker on it by memory no sure if chiped or not ?
change of plans, also need a set of good secondhand R32 gtr injectors, just a stock ecu, NOT a chipped ecu
I Have coilpacks now, may still be requiring two stock 32gtr afm's
Question: my gtr is a 90 model will a 92 or 94 ecu work without issues?
I have 2 ecu here one is stock pulled out 3 weeks ago out of 91 model $80.00 and asio have modded unit out of 90 model 110.00.
stuart 0409135950
Im just at this stage interested in the stock one, Ill give you a call, tues or wednesday, cheers Damo
Look forward to hearing from u.
stuart
hey stuart, thankyou very much for the offer, i managed to get a package deal with afm and an ecu with a delimiter, I wish you well selling ure gear and thankyou for responding, cheers Damo
