hey guys got some stuff
greddy type ls cooler, almost new only done 100ks ($550)
custom radiator koyo replica, fits straight into r33 no mods to be done ($350)
gizmo 4 stage digital boost controller. "awsum piece of hardware"($300)
apexi power intake pod on its on. ok condition. ($50)
3.5 inch magnaflow full turbo back exhaust with 4.5 inch tip, very loud, awsum rb rumble.($500)
climate control unit. no scratches on screen (80)
make an offer on the following
door trims
parcel shelf with black carpet
passenger seat with rails
backseats
seat belts
dash cluster 200000ks
glove box
and others
ask me wat ur lookin for and ill see wat i can do guys..
any questions anytime 0421969340 trent
thanx
https://www.sau.com.au/forums/topic/285907-r33-parts-brand-names/
  • 3 weeks later...
Heads up to all:
I haven't had any response from Trent via PM or SMS for over a week now. I'm not sure what happened, but I haven't received the cooler either. =-[
