Hi all
I have a R34 GTT stock side mount intercooler SMIC for sale. Great upgrade for your Stagea or R33 up to 200rwkw, great response, no defects
It is in great condition and comes with the air duct
In south west Sydney, $150
Thanks
https://www.sau.com.au/forums/topic/285921-r34-gtt-side-mount-intercooler-smic/
  • 3 weeks later...
