Momo Steering Wheel With Boss Kit, R33 Coolant Overflow Bottle
GENUINE MOMO STEERING WHEEL
-WAS FITTED TO A NISSAN SKYLINE R32 GTR COMES WITH A BOSS KIT AND MOMO HORN.
-BOSS KIT TO SUIT A R32 GTR SKYLINE
-PERFECT CONDITION
$150 ono
R33 NISSAN SKYLINE GTST AUTOMATIC GEAR SELECTOR
-GOOD CONDITION USUAL WEAR MARKS ON TOP OF GEAR KNOB
-SELLING DUE TO CONVERTING MY CAR FROM AUTO TO MANUAL AND NO LONGER OWNING CAR
$25.00 ONO
R33 NISSAN SKYLINE OVERFLOW COOLANT BOTTLE
-CAP IS MISSING
-SELLING DUE TO NOT OWNING THIS CAR ANY MORE
$25.00 ONO
GReedy STYLE RB25 GTR LOOK INTAKE MANIFOLD
-THIS ITEM IS NEW AND I NEVER FITTED THIS INTAKE MANIFOLD TO A CAR SO I AM UNSURE IF IT IS A DIRECT BOLT ON.
-I BOUGHT IT OFF MY MATE WHO PAINTED IT IN HI TEMP BLACK PAINT.
-IT IS NOT A GReedy manifold
$350ono
All items are negotiable please sms or call me
Phone 0429995764
R33 gtst automatic gear selector and coolant over flow bottle are now free to good home I just want them out of my shed or they are going in the bin next rubbish pick up
  • 4 weeks later...
I am throwing the over flow bottle and auto GEAR SELECTOR out tonight.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
