Hi Guys
I have had these gauges for ages since I had massive rear end damage on my R32 and written off a few years ago,
Gauges are race tech, and look practically brand new, blue backlight and in A pillar mounted POD
no wiring,
will sell two gauges in POD for $150
only installed for 2 months before removed from car.
normally sell for $90 each and POD is maybe $40 i not entirly sure,,,
they look like very simular to these http://www.elite-electronics.com.au/incar/...0gauges_gal.jpg
email : [email protected]
Mob : 0415 824 988
gauges and pod looks just like this, except mirrored to the right side, with boost in front and water temp behind,
http://i21.photobucket.com/albums/b265/ste...ff/IMG_3928.jpg
will have to organise some actual pics,
oh I see, so are you separating that pod from the gauges? because I'm very interested in the pod... also are you located in Melbourne?
okay fair enough mate, what brands the pods anyway?
please contact if your looking to separate the pod from the gauges...
gl with sale
  • 3 weeks later...
  • 1 month later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
