Hey guys, im putting my silvia up for sale. Its a 1989 K's model, CA18DET, 5 speed manual in green over grey two tone. Specs are as follows;
Engine:
CA18DET, 150,xxx KMS*
Apexi pod filter
R32 GTR front mount intercooler
Hi flowed turbo, rebuilt with 2860rs internals, only done about 2000kms and have all paper work from when it was bought
AM Performance dump pipe with screamer
AM performance 3" stainless steel exhaust with kakimoto muffler
Just had bearings and front and rear main seals done
Body:
Standard body in good condition, green over grey two tone paint. There's a few marks in the paint, and a few small dents here and there, but overall good.
Interior:
All stock interior in immaculate condition, no cracks in the dash. CD player with mb quartz speakers. Also has rare "cup holder" center console lid and "cool box" in the glove compartment
Suspenison/brakes
Non hicas model, upgraded to s14 5 stud hubs, disks and calipers, with slotted rotors and ebc greenstuff pads. Isc coilovers all round, with adjustable camber tops up front and isc camber arms in the rear. kazama castor rods and a cusco front strut brace. Recent wheel alignment done at Adelaide Radial Tire
Wheels
Work VS XX 17x8 +10 all round with 8mm spacer on the front using nismo long studs all round
Misc
new clutch plate, only a few weeks old. I also have an omori boost gauge and a z32 afm that can be negotiated with the sale.
I recently serviced the car, replacing all the major filters and fluids. There's probably a few things ive missed, but feel free to ask. The car is available for viewing weeknights and weekends so just give me a call if your interested and we can work something out. Im asking $11800 ono. I can be contacted any time on 0431 297 568. Cheers guys.
https://www.sau.com.au/forums/topic/289480-s13-silvia-ks/
k's= turbo
Q's= non turbo
slightly overpriced for a CA18DET s13 these days mate........... but it is very very nice maybe around $7500 without wheels and $9000 with?
Edited by slidwaz
https://www.sau.com.au/forums/topic/289480-s13-silvia-ks/#findComment-4847651
k's= turbo
Q's= non turbo
his car his price. . .
https://www.sau.com.au/forums/topic/289480-s13-silvia-ks/#findComment-4847865
thanks mate, i think the price is reasonable considering the new turbo, fresh bearings, and all of the susp. work. also forgot to mention, fairly new tires and rego till january. Also, the price is negotiable guys, i've put a deposit on a new car so i need to sell fairly soon so make me an offer.
Edited by heslo's + 1
https://www.sau.com.au/forums/topic/289480-s13-silvia-ks/#findComment-4848603
thanks for the kind words guys, yeah it goes pretty well for what it is. Dropping the price now to 11k. Also forgot to mention that it has a full alarm/imobiliser/central locking.
https://www.sau.com.au/forums/topic/289480-s13-silvia-ks/#findComment-4854702
wat bearings did you have done??
but yea 11 is a lil bit high, espec coz its ca, if it were sr then yea that different, if it was like 9ish i would seriously consider coz i want this colour scheme but yeh, price changes everything
https://www.sau.com.au/forums/topic/289480-s13-silvia-ks/#findComment-4867617
the bottom end bearings and the front/rear main seals were replaced just a few weeks ago, ive got all the receipts for the work. Ive priced it at 11 "neg" as i was expecting people to come in with lower offers. Give me a call mate, if you want to come have a look at it, we could probably work out a price around what your talking about. My number is 0431297568. Cheers.
https://www.sau.com.au/forums/topic/289480-s13-silvia-ks/#findComment-4868543
  • 3 weeks later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
