Autobarn Warners Bay - Grand Opening - 10th/11th Oct. Prizes, Giveaways, 20%off!
Started my new job a few weeks back, as an Autobarn Automotive Electronics Technician (Fitter). We're all still putting the store together, building racking & recieving heaps of stock every day.
Autobarn - Warners Bay Homemaker Centre
240-260 Hillsborough Rd
PH: 49537461
[email protected]
We'll be open from roughly 7th/8th of Oct, but our grand opening event will be on the 10th & 11th (Sat & Sun).
There'll be a BBQ firing all day.
Theres a 20% Off Sale.
Heaps of our supplier's reps will be there, giving away showbags & showing off their products, equipment, sound systems & cars.
There'll be Racing Simulators & prizes for the fastest drivers.
Grid Girls will be there, along with Pauly & Kev The Kiwi from Fat Pizza!
And everyone will be able to go in the draw to win a 42" Plasma & a Home Entertainment System.
Heres some flyers -
http://www.filefactory.com/file/a0c01h7/n/AUTONSWW02695_WARNERS_BAY_V14_1_pdf ;)/http://www.filefactory.com/file/a0c..._BAY_V14_1_pdf
http://www.filefactory.com/file/a0c0100/n/...S_BAY_V17_1_pdf
http://www.filefactory.com/file/a0c01gc/n/...rs_Bay_V2_1_pdf
See you all there! :P
Edited by E.k
how did it go? i came to get a couple of things but couldn't get in the carpark cause it was full! So i'm assuming it went well! :P
Yeah it went off, was non-stop all day!
Drop in if you guys need anything. If we dont have it here, we can get it in.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
