Housemate is getting cranky with car parts sitting in the lounge room so clearing the stuff that I don't really need. Willing to post any items, buyer pays post.
Items are all located in Geelong (3220)
Part of a Tomei 3 part strut brace. **Note that this is only one part** (See pics below)
$150
Apexi Boost guage - works perfect and glows blue. Removed to replace with another item I had
$60
Clear passenger side indicator*
$45
Orange drivers side indicator - slightly faded*
$30
*Please refer to pics, as clip is broken on both indicators.
Cheers :)
Edited by stealth-ish
https://www.sau.com.au/forums/topic/291974-r32-brace-indicators-boost-gauge/
GAUGE is GONE
forza5, ill send you a pm tomorrow as i'll know for sure if its sold or not
do you think you could post your number here? i havnt made 10 posts yet and cannot check my inbox at this time.
i can pick it up asap
ahh need that driver side indicator send me your datails
cheers
pm sent
I will get back to you later this evening, pending if i hear back from another member. Have you got an email address i can catch you at otherwise?
keen on clear indicator if you have a pair???
I dont have a pair sorry. otherwise as per above if i dont hear back from another member forza5 may get it.
first in best dressed guys!
