Hey guys n girls
have a
Iriver T6 mp3 player - $80
4gb space
Black in colour
nice and compact
slim design
comes with headphones in box
mp3, wma / fm radio with recording / photo.jpg / high speed usb 2.0 / voice recording
Iriver website
item is brand new, hasnt been opened, still in its plastic wrapping.
was bought for grandma but she wanted something similar to a small ipod lol.
has reciept for $90
take it for $80
located in Rowville. S.E suburbs Melb
https://www.sau.com.au/forums/topic/292479-irivier-t6-black-4gb-mp3-player/
  • 3 weeks later...
Dont know if you can anser this question, i often play long files (3-4hrs) do you know if when you turn it off or battery goes dead in the middle of the file when its started again will it play from the same point where it last ended or will it go back to the start?
  • 3 weeks later...
hey not too sure, majority of mp3s i know usually continue from where you left off.
bump
grab someone a christmas gift :laugh:
