Here we have an S13 with a 5 speed manual turbo 1.8l engine. Engine was given a freshen up about 18 months ago with acl rings, bearings and mls headgasket. At the same time all seals, gaskets and clutch kit were done. It has a garrett t28bb turbo which blows no smoke with an intercooler kit and a 3in exhaust with a varex rear muffler. It has also had new radiator and heater hoses and a kit in the clutch slave and master cylinders. Engine has bosch coil conversion and is running 10psi boost there are also sports shockers fitted in the standard struts. Has 17inch speedy wheels with good tread and new brake pads. Inside has a full stereeo system, cruise control, climate control with ac that works, turbo timer, boost gauge. All electrics work fine and there is no rust around the sunroof, has tinted windows and a full alarm system with remote entry. The body has a few minor dents and scratches and the seats have come appart at the stitching but are still comfortable to sit in. Car is driven daily and is serviced every 5000km. Has not missed a beat in the 18months I have had the car on the road. Bought a new project so it has to go. Contact me for more info I am sure there are some small things I have missed. Asking $7500 and located in Murray Bridge SA. 0439379759.
Edited by bradr8
https://www.sau.com.au/forums/topic/294343-fs/
  • 3 weeks later...
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
