  • 3 weeks later...
  • Replies 43
  • 4 months later...
  • 4 weeks later...
  • 2 months later...
Goddamn that thing is porn.
Is it down in Aus yet?
Does this mean that the workshop you get it complied with can comply other C35s?
i'd assume it'd be personal import , but contact iron chef imports , last time i was talking to him they were about to be passed for aus compliance or whatever they call it :/
yeh, no compliance for me. its personal import. im still waiting on the papers from the government. its been over a month since they last contacted me.
i want to drive it at chrissy time when im back in aus.
these are on the SEVS list but there wont be many coming into to aus as the turbo autos are few and far between. everythings non turbo auto or turbo manual.
  • 4 weeks later...
  • 3 weeks later...
  • 1 month later...
well christmas came and i got it regod and finally drove it on aust streets :rofl::D
was a good feeling to have it all fall into place
only photo i have of it from aus is before i put the cover on it on my way back to japan
Edited by adam87
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
