Super Special Discounted Advanced Car Control Course
Saturday 16th January 2010
Driver Dynamics will be hosting a specially discounted Advanced Car Control Course at Sandown Raceway Melbourne on Saturday 16th January 2010
We offer these specially discounted courses once per year at Sandown Raceway.
This course is suited to all drivers and is focused on raising the drivers awareness of vehicle dynamics, advanced vehicle control skills, and how even small increases in speed can dramatically affect the degree of vehicle control difficulty.
The format is very much ‘hands on’, with the emphasis on practical driving exercises, including highway speed emergency braking, wet corner emergency braking, emergency lane changing, multiple direction changes, understeer and oversteer exercises, and vehicle stability exercises on our unique ‘split surface’ system.
This is a full day course starting at 8.30am and concluding at 4.00pm.
Note that this is not a trackday, there is no circuit lapping.
You dont need a helmet or any special modifications to your car.
Normally drivers would expect to pay up to $300.00 or more to attend such a program, but we’re offering this date for only $195.00 per driver.
Note that this price also includes lunch and soft drinks.
These courses fill very fast, so if you’d like to attend please call Tessa on 1300 652 693 Or email [email protected]
Kind regards
Kev
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
